Several versions of MPManager user interface and of NFC Forum test suites are available on the download centre.
It is important to know which version of MPManager to use with the test suite I want to execute.
Could you provide a table indicating which firmware and MPManager versions are recommended to be used with a given version of the NFC Forum Analog test solution?
