LabVIEW Error -2519 Occurred at TDMS Open
Updated May 20, 2024
When trying to open TDMS file in LabVIEW, I receive Error -2519 occurred at TDMS Open. How do I resolve this issue?
This error occurred because LabVIEW could not load the TDMS file component. The component is expected in the National Instruments\shared\TDMS directory. You might need to reinstall LabVIEW to fix this problem.
Alternatively, check the drive where you installed LabVIEW. For example, if you installed LabVIEW at D: drive instead of C: drive, copy the contents of "D:\Program Files (x86)\National Instruments\Shared\TDMS" to "C:\Program Files (x86)\National Instruments\Shared\TDMS".
