Emvco Picc Analog Extended Test Suite Is the Failing Ts Configuration
Updated Feb 11, 2020
  • Micropross Accessories
I am running the EMVCo PICC Analog Extended test suite and I am failing the setup cases Ts Configuration and Ms Configuration with error messages "Error during acquisition" and "Ts Configuration inconclusive"I have double-checked that all of my connections are correct and I have updated all of my software and drivers.
Why am I seeing this error?
This error can occur when there is a connection issue between subsystems of the CTS. Please make sure the connection between the CMR/LMA and the CTS is correct.
More specifically, ensure that the connection between J2 on the EMV Reference PCD and J2 on the CMR is robust. Usually, this issue appears due to a faulty cable or worn connectors. Try to swap out this cable for a known good or new cable and see if the problem persists.
If the problem continues, please contact NI NFC support here.
