Archived:Back-End Compiler Failure When Converting Code from LabVIEW to NXG
Updated Jan 6, 2022
  • LabVIEW NXG
I converted my LabVIEW code to LabVIEW NXG, and when manually correcting it, I get the following error message:
Error Main.gvi The back-end compiler for this deploy target failed with an exception while processing this file. The file may be corrupt or there may be a bug in the back-end compiler. Consider undoing recent edits, closing and reloading the current project, or restarting the application. Control-clicking the run or compile buttons will force another compile attempt. For help with this issue, please contact National Instruments or the third-party vendor responsible for this target compiler. Target kind: NationalInstruments.Target.NativeDesktop, File name: ::DevSystem::Interactive:: Exception: NationalInstruments.Compiler.CompileException
This error can be resolved by following two steps:
1. Mass compile the original LabVIEW code.
2. Work through the conversion guide step by step, using the instructions in the following three articles:
