How Can I Make New Excel File using Report Generation Toolkit?
Updated Nov 8, 2019
I want to make new excel file using Reprot Generation Toolkit. But, When I use New Report.vi and set the reference directory, the error 7 occurs.
How can I make new excel file?
Error 7 occurred at NI_Excel.lvclass:new report subVI.vi -> NI_report.lvclass:New Report.vi -> Untitled 1
Possible reason(s):
LabVIEW:  File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
Nonexistent GPIB interface.
If you want to create a new excel file, you should remove the New Report.vi Template wire. Please refer to the picture below.
If you want to modify or import an existing file, you should connect the line to the New Report.vi Template Input.
Microsoft Words case is same.
