Where Can I Find Electromechanical Relays on Multisim?
Updated May 4, 2023
  • Multisim
I want to place some electromechanical relays on multisim but all that I find are regular relays and relay drivers.
Where do I find the electromechanical relays?
The electromechanical relays can be found on the master database by going to the COILS_RELAYS section:
If you want to increase the amount of pins on a relay you will need to add another relay in the design, replacing the one already in place.
