I tried installing software from NI Package Manager and received the following error:Unable to locate package <software package and version> with a compatible version and architecture.
NI Package Manager (NIPM) can encounter issues locating dependencies under different circumstances, some steps you can cover to address this:
There is also a chance that there was a patch publishing in process. If this is the case, you will need to try installing at a later time or use an offline installer in the meantime.
