I cannot set my application as startup on my cRIO-9035
Updated Oct 9, 2019
  • cRIO-9035
I have finished the development of my application and I would like to deploy it as a startup application on my cRIO-9035. However, if I follow the instructions , it is not possible. When expanding Build Specifications, under new I can only see Source Distribution
To be able to create a stand-alone application in LabVIEW, you have to have an Application Builder Module installed. Without it, it is not possible to create build specifications and set the application as a startup.
