Converting an NI-DAQmx VI into a cRIO-905x Labview Project
Updated Oct 8, 2019
  • CompactRIO Controller
  • I want to reuse the code for an exixting CompactDAQ based application on my cRIO-905x.
  • I cant make the NI-DAQmx VIs recognize the C series modules' physical channels, how do I do this?
These is a tutorial that shows how to do this migration with cRIO-904x so you can create DAQmx tasks using the physical channels of the modules inserted on the controller. The steps to do this with cRIO-95x controllers are the same. Just make sure to use the appropriate software for utilizing the cRIO-905x .
