Controller Shows Warning or No Network on Ethernet
Updated Oct 8, 2019
  • PXI Controller
I have a PXI or PXIe controller which is showing me a warning label on the network connection. How can I fix this?
Try the following steps to try to resolve the network issues:
  • Try the troubleshooting steps recommended by Microsoft in Windows
  • Try rebooting the chassis
  • Try pinging the device from the same network
  • Make sure there are no network firewalls or rules preventing communication between devices.
Many times there are IT firewalls or communication rules which prevent certain network communications.  You may need to get the controller to be set up by your IT department before it will function.
