Cyclic Redundancy Checks When Using NI 9350
Updated Oct 8, 2019
  • NI-9350
I have a cRIO chassis containing the Functional Safety Module NI-9350. When I am running a LabVIEW code, I receive the following error:
Error -65492 occurred at Shared Variable in FpgaInterface.lvlib:ActionReadSafetyInputs.vi->FpgaInterface.lvlib:ActionExecuteStateAction.vi->FpgaInterface.lvlib:ProcessLoop.vi->MAIN-RT.vi
Possible reason(s):
The operation failed because of CRC error. Check the module power supply and reinsert the module.
This error or warning occurred while reading the following Shared Variable:
\\RT<file:///\\RT> CompactRIO Target\Mod8\Var1
\\192.168.1.10\Mod8\Var1<file:///\\192.168.1.10\Mod8\Var1>
Why is this happening and how do I fix this?
This error occurs because the scan engine has been set to an unstable speed (faster than 1kHz). To fix this, right-click the chassis in the LabVIEW project and set the scan engine to be 1ms or slower.
