Can I Swap the Connector Blocks on My NI 9212
Updated Nov 30, 2023
  • NI-9212
I have a NI 9212 Thermocouple module that has either the Screw Terminal Block or the Mini-Thermocouple Block on the front, can I swap it out for the other front-end block?
Figure 1: Part Comparison
The exact same module is behind the terminal block of the 9212 so either connector-block is compatible- swapping out front-end block is possible.
