To transfer files from one CompactRIO to another CompactRIO, you must specify a WebDAV server and a client, respectively.
Through the Software Add / Eliminate tab in MAX, you must install the WebDAV Server software on CompactRIO acting as a WebDAV server and install the WebDAV Client with SSL Support software on CompactRIO acting as a WebDAV client.
And then, you can perform a file transfer test using the example provided in the following snippet.
