It depends of the device you are using.
If you are using a MP300 or a MP500, this function is only use to record and display (in the MPManager viewer) the exchange when the device is part of the transaction.
If you are using a MP007, this function is use to activate the external spy feature.
You can also use the associated command in the
Script panel of MPManager :
