How Can I Configure cRIO on NI Linux RT as a WebDAV Client?
Updated Jul 29, 2022
  • CompactRIO Controller
  • NI Linux Real-Time
In the WebDAV shipping example provided by NI, cRIO-9065 acts as the server and Host PC acts as the client.
However, I want to designate cRIO-9065 as a WebDAV client and configure my Host PC as a WebDAV Server. Is it possible to configure my cRIO-9065 as a WebDAV client?
Yes. You can configure your cRIO-9065 as WebDAV client by using install the software in MAX.
If NI CompactRIO driver was already installed in your PC, you can install the WebDAV Client with SSL Support through Add/Remove Software tab in MAX.
User can also make the cRIO-9065 a WebDAV server by installing WebDAV Server in Add/Remove Software tab.
