Using Relay Control Function on the PXI-2510 Pass-Through Channels
Updated Oct 2, 2019
  • Fault Insertion Module
  • PXI-2510
  • NI-SWITCH
I am using relay control functions from NI-Switch driver to control my PXI-2510. I have noticed that when I use the niSwitch Relay Control.vi on any of the pass-through channels, it performs the opposite action. The close relay action opens the channel from the DUT, while the open relay action closes the channel to the DUT.
The pass-through channels (chN to dutN) on the PXI-2510 are connected (closed) in its power-on or reset state. The niSwitch Reset.vi and niSwitch Disconnect All Channels.vi function will connect the pass-through channels.
If you are using the niSwitch Relay Control.vi to operate these relays, please note that using the close relay action on relays (k0 through k67) will actually disconnect the pass-through channels and vice versa.
The pass-through channels are connected in the PXI-2510's power-on or reset state, these channels may need to be disconnected during a scanning operation. In order to disconnect the channels during a scan, set the Scan Mode property to None.
