NI Veristand Model Rate Doesn't Reflect Imported Model Rate
Updated Oct 25, 2019
  • VeriStand
I have created a model using a 3rd party software and imported it into NI Veristand. In the System Definition, I see that the Model's Rate is lower than what I had configured it to be.
Ensure that the model rate is not faster than the rate of the Primary Control Loop set in the Controller Settings. The Model Rate must be an even division of the Primary Control Loop rate.
