Unable to Adjust Rf Field with MPMANAGER Script
Updated Oct 23, 2019
  • Micropross Accessories
Other
SW: MPMANAGER 3
HW: MP500
Using a card emulation scrip with MPMANAGER, I have the following error :
Unable to adjust RF field threshold (error 614)
  1. Check the cables connections between the MP500 and your antenna
  2. Ensure that you connected your antenna to Aux 1 port of your MP500. If you're changing the connection, you must reboot the MP500.
  3. Check if the PCD field is On
  4. Launch the script
If the issue isn't solved, please contact NI NFC & Wireless charging technical support: mp-helpdesk@ni.com
