You can check the installed version of OpenSSL by following the instructions below. The OpenSSL library is replaced by the latest version after the LabVIEW upgrade and is used by all NI software.
- Open a command prompt
- Type cd C:\Program Files\National Instruments\Shared\nissl to change directory
- Type openssl.exe to run
- Type version
The version information is output as follows.
For information about SSL refer to
The Most Common OpenSSL Commands.
