Disable CAN frame transmission in VeriStand
Updated Oct 26, 2026
  • PXI-8513
  • PXI-8512
  • PXI-8511
  • PCI-8513
  • PCI-8512
  • PCI-8511
  • VeriStand
  • NI-XNET
I am doing an ECU fault test with VeriStand. In some test cases, the outgoing CAN frame needs to be paused.
Is it possible to stop the CAN communication and start over?
Yes, You can disable and enable CAN frame transmission by checking Disable transmission on CAN Frame setting.
You can configure the settings by following steps.
1. Creating User Channel : You are going to Disable or Enable CAN Frame with this user channel
Please refer Additional Information for User Channel creation.
2. Disabling CAN Transmission
 (1). Click CANCylclicFame1(64), the CAN frame you want to disable >> Check Disable transmission check box
 (2). Click Browse icon and select Disable User Channel
3. Control Disable User Channel in WorkSapce
 (1). You can add Boolean Control and select Disable User Channel as shown below
 (2). Now you can control the CAN frame transmission with the Boolean Control
 You can see the CAN frame is transmitting when the Boolean Control is off. The signals on the right is the CAN signal measured with VirtualBench Scope.
When the Boolean Control is on, the CAN frame is disabled as shown below.
User Channel Creation
1. Open System Definition File >> Click User Channel >> Click Add User Channel
2. Naming the User Channel
