Can VirtualBench be Used as a Measurement Instrument in Multisim™?
Updated Mar 30, 2023
  • VirtualBench All-in-One Instrument
  • Multisim
  • I want to be able to use VirtualBench as a measurement instrument in Multisim™
  • Can VirtualBench be used to monitor signals while simulating in Multisim™?
VirtualBench is accessible in Multisim™ as an instrument. However, it can only be used as a signal source. In order to monitor or measure signals, a different instrument (such as an oscilloscope) should be used.
In order to access VirtualBench in Multisim™, the attached VB_Multisim_Library.llb is required. This library must be installed to:
C:\Program Files (x86)\National Instruments\Circuit Design Suite XX.X\lvinstruments
(where X symbolises the version of Circuit Design Suite).
