Trigger Same Event with Two Booleans
Updated Sep 11, 2019
I would like to be able to trigger one event using multiple boolean controls. For instance, I would like Boolean A and Boolean B to trigger the same event. Is there a way to do so?
You can add event sources to a single event by right-clicking the border of the Event structure and selecting Edit Events Handled by This Case and adding event sources.
Following are detailed steps:
  1. Right-click the border of the Event structure and click on Edit Events Handled by This Case
  1. Click Add Event
  1. Select the second event source you would like to add and click OK
  1. Confirm that it has been added as an event source.
