Syntax for Using the Call Executable Step Type in TestStand
Updated Sep 4, 2019
  • TestStand
I am trying to use the Call Executable step type in TestStand to call an executable for one of my company's internal tools.  What syntax should I be using to send commands/arguments to the tool?
The Call Executable step type in TestStand operates just like the command line would.  Use the same syntax/commands you would use to call your executable in the command line when you call it using TestStand.
