How Can I Modify the Width of Horizontal Axis on Waveform Chart?
Updated Sep 12, 2019
I am using a waveform chart that shows the acquired data by a DAQ device. It seems that the width of the horizontal axis is fixed on the waveform chart. Is it possible to modify the width?
You have to change the width by right-clicking the waveform chart and choosing property option. In the property option, you can set the minimum and maximum value of the waveform chart. Here, you can modify the width of the horizontal axis.
 If you want to keep this setting when you open the VI again, you have to right-click the waveform chart and select Data Operations>>Make Current Value Default
