Yes, with these type of cRIO, it is possible to see the C Series Modules in NI-MAX and to test them with same test panels as with cDAQ.
In order to do this you have to :
- Expand the "Devices and Interfaces" list of the concerned cRIO and select your module
- Configure the module as "Real-Time (NI-DAQmx)"
- You will be able to use the test panel
For cRIO devices that are not DAQmx compatible, the C Series modules can be tested using Distributed System Manager.
Information on how to do this can be found inĀ
Monitor NI CompactRIO System Resources and I/O with the Distributed System Manager.
