LabVIEW Executable Opens Slowly
Updated Mar 30, 2023
My LabVIEW executables open very slowly on either my development or deployment PC. This occurs even if the executable is an empty block diagram and blank front panel.
In your Windows Search Bar, navigate to Control Panel>>Internet Properties>>Advanced. Uncheck the following options:
  • Check for publisher's certificate revocation
  • Check for server certificate revocation*
  • Check for signatures on downloaded programs
Click Apply then OK to close the Internet Properties Window and try running your executable again.
