I Have a Shutdown Error When I Start Mpmanager
Updated Oct 25, 2021
  • Micropross Accessories
  • MPManager
Other
Sw : MPManager 3.x (all the versions)
There is a error when we open MPManager 3. MPManager will shutdown and a fatal error which appears :
First, please execute MPManager in administrator mode.
If the issue is still present, you will have to delete everything which is contained in the following folder :
C:\Users\Micropross\AppData\Roaming\Micropross\
