Unexpected Quality Bits in NI IEC 61850 SMV Stream
Updated Aug 27, 2019
  • cRIO-9049
My application needs to conform to 61850-9-2LE and so I need to be able to set the derived bit. How can I go about doing this?
The NI IEC 61850 is developed based on the third-party's stack. And we leverage the stack standard only (IEC 61850). The quality is defined as the highest 13-bits in the stack. Also, NI SMV does not support setting the derived bit.
