Archived:Restarting My cRIO Controller in NI MAX if the Username and Password Is Forgotten
Updated Sep 7, 2026
  • CompactRIO Controller
  • CompactRIO Chassis
I have recently changed my cRIO controller password but unfortunately, my new password cannot be used. It always pops up the incorrect username or password error message when I try to log in with the new password to restart the cRIO controller. I cannot use the hardware restart because the cRIO controller is not physically present. How can I restart my cRIO controller in NI MAX?
One of the ways to restart the cRIO controller if you cannot log in with the password in NI MAX is, by using the NI Web-based Configuration and Monitoring tool. Follow the instructions below :
  1. Open NI MAX, and find the cRIO controller under Remote Systems.
  2. Click the Set Permission button to open the NI Web-based Configuration and Monitoring tool.
  1. The NI Web-based Configuration and Monitoring tool will be opened in a browser, then click the Restart button to restart the cRIO controller.
