Open Inspection Warning in NI Vision Builder for Automated Inspection
Updated Sep 12, 2019
  • Vision Builder for Automated Inspection
I am copying over my Vision Builder application to a new computer. However, I am getting a warning when opening my Vision Builder application that says the following:
The validation of the inspection steps returns errors.
The image below shows an example of the warning I am seeing:
Additionally, when trying to run the application the application fails and returns a FAIL Inspection Status along with a Call By Reference in IVB message.
The image below shows an example of the inspection step failing with the message listed.
This could be caused as a result of opening the application in the wrong version of Vision Builder. Ensure you have the correct version of Vision Builder installed on your new computer when moving over your application. If you need to download Vision Builder, ensure your serial number is connected to your ni.com account and download the correct version from the Vision Builder for Automated Inspection Download Page.
