配置LIN Diagnostic Frames的Session中出现错误-1074384547
更新 Mar 24, 2025
硬件
  • USB-8506
驱动
  • NI-XNET
我正在尝试使用USB-8506创建一个传输LIN Diagnostic Frames的LIN Session。当我运行 XNET Create Session (Frame Output Single-Point).vi时,出现错误-1074384547并显示以下消息:
Error -1074384547 occurred at XNET Create Session (Frame Output Single-Point).vi
Possible reason(s):
NI-XNET:  (Hex 0xBFF6315D) You have tried to create a session using a frame that is incompatible with the selected session type. For example, you are using a LIN diagnostic frame with a single point output session.
我该如何解决该错误?
发生错误是因为LIN Diagnostic Frames是不支持single-point session。
请参考NI范例查找器>>硬件输入与输出>> LIN >> NI-XNET >> Advanced 的范例LIN Diagnostic Frames Master.viLIN Diagnostic Frames Slave.vi
