Receiving Error -1074384547 When Configuring Session for LIN Diagnostic Frames
Updated Apr 23, 2021
  • USB-8506
  • NI-XNET
I am trying to use USB-8506 to create a LIN session that transmits LIN diagnostic frames. When I run XNET Create Session (Frame Output Single-Point).vi, I receive Error -1074384547 with the following message:
Error -1074384547 occurred at XNET Create Session (Frame Output Single-Point).vi
Possible reason(s):
NI-XNET:  (Hex 0xBFF6315D) You have tried to create a session using a frame that is incompatible with the selected session type. For example, you are using a LIN diagnostic frame with a single point output session.
How can I resolve this error?
The error occurs because LIN diagnostic frames do not support single-point sessions.
Please refer to shipping example LIN Diagnostic Frame Master.vi and LIN Diagnostic Frame Slave.vi from NI Example Finder >> Hardware Input and Output >> LIN >> NI-XNET >> Advanced.
