To get rid of this, you will need to download the software that is missing and activate it.
The missing software is most probably different from NI GOOP Development Suite, and thus, you may need to find out what is missing from your system environment as below.
- Load VI
- Close error pop-up window
- Look for any broken functions or sub-vi on block diagram
a) If you found broken parts, find out what software/toolkit is associated with it
b) Install required software/toolkit
