What Is the Resolution for the NI 9202?
Updated Mar 24, 2025
  • NI-9202
I would like to know the resolution for the NI-9202 module. Where can I find it?
Resolution is theoretically the smallest amount of input signal change that the module or sensor can detect. The number of bits used to represent an analog signal determines the resolution of the ADC. The NI-9202 module is a 24-bit module with ±10 V range , which means that lowest amplitude change that can be detected is 1.19 µV.
