Can't Add Ethernet cDAQ by Hostname on Host Computer Running RHEL8
Updated Oct 1, 2019
  • cDAQ-9189
  • cDAQ-9185
When I try to access my Ethernet cDAQ device by hostname from my host computer running the Red Hat Enterprise Linux 8 operating system, my Ethernet cDAQ cannot be found. How can I use my Ethernet cDAQ?
RHEL8 is not configured to perform mDNS lookups for .local hostnames by default, so the cDAQ hostname cannot be resolved. The cDAQ can still be used by calling the IP address instead of the hostname.
For example, this command will fail:
nidaqmxconfig --add-net-dev <Hostname>.local
While, this command will succeed:
nidaqmxconfig --add-net-dev <IP Address>
