Error -2147220370 When Utilizing My Real-Time Controller in NI RAD Utility
Updated Oct 28, 2026
  • CompactRIO Controller
  • PXI Controller
  • Replication and Deployment Utility
I'm trying to use NI Replication and Deployment Utility (RAD) to retrieve an image of the software running in my Real-Time Controller, but I am receiving the following message:
Error -2147220370 at nisyscfg.lvlib:Set System Image (Folder).vi:20%
<b>Complete call chain:</b>
nisyscfg.lvlib:Set System Image (Folder).vi:2060001
nisyscfg.lvlib:Set System Image (File).vi:4160001
rad_Deploy Image Wrapper_FB.vi:2760002
How can I fix it?
The RAD Utility relies on network protocols to perform low-level controller operations, rebooting into Safe Mode and image transfers. The error -2147220370 means that:
  • We can only perform this action in safe or install mode, so, the 'auto restart' flag was false.
  • There is no communication with the controller.
To fix that, please verify the following:
  • Avoid any hardware bridges between the Host PC and the controller, such as a network switch or dock stations. Make sure to have the Real-Time controller directly connected to the Host PC through an ethernet cable.
  • Temporarily turn off Windows Firewall or enterprise security software on your Host PC, as they can block communication over the network.
  • If the previous steps do not fix the issue, plese refer to the following procedure:
    1. Access the shell of your Linux Real-Time Controller
    2. Open the following configuration file by running the command below:
      vi /etc/ni-rt.ini
    3. Modify the file editing the line
      RTTarget.LaunchAppAtBoot=FALSE
      to
      RTTarget.LaunchAppAtBoot=TRUE
    4. Save the changes
    5. Reboot the controller to apply the changes
After that, RAD Utility should run normally.
