Measure Analog Input on NI 9237
Updated Aug 19, 2019
  • NI-9237
Can you measure pure analog input using the NI 9237 module?
It is not recommended to use the NI 9237 to measure a pure analog signal. The measurement on the NI 9237 is based on a ratio-metric value of the bridges normally on a strain based sensor. Due to this, the analog input measurement would not be accurate.
