Archived:Supported FPGA Targets for FPGA IP Builder
Updated Nov 22, 2019
  • LabVIEW FPGA Module
  • LabVIEW FPGA IP Builder Module
What FPGA targets does FPGA IP Builder support?
The following table lists the FPGA targets that FPGA IP Builder supports.
Device TypeTargetNote
CompactRIOcRIO-903xAppears only if you add a top-level target in a project. Requires the LabVIEW Real-Time Module.
cRIO-906x
cRIO-9075
cRIO-9076
cRIO-908x
cRIO-911x
cRIO-FRC II
Ethernet RIONI 9146Appears only if you add a top-level target in a project. Requires the LabVIEW Real-Time Module.
NI 9147
NI 9149
FlexRIOPXI-795xRNone.
PXIe-796xR
PXIe-797xR
IF DigitizerPXIe-5624RAppears only if you install NI LabVIEW 2014 support for NI PXIe-562xR.
IF TransceiversPXIe-5641R
PCI-5640R
Appears only if you install the NI-564xR instrument driver.
MXIe-RIO ChassisNI 915xNone.
myRIOmyRIO-1900None.
myRIO-1950
R SeriesPXIe-782xRNone.
PCIe, PXI, USB-784xR
PCIe, PXI, USB-785xR
Real-Time Single-Board RIOsbRIO-9605Appears only if you add a top-level target in a project. Requires the LabVIEW Real-Time Module.
sbRIO-9606
sbRIO-9623
sbRIO-9626
sbRIO-9633
sbRIO-9636
sbRIO-9651
USRP RIOUSRP X310Appears only if you install NI USRP RIO.
USRP-294xR
USRP-295xR
Vector Signal Transceiver (VST)PXIe-5644RAppears only if you install the NI PXIe-5644R/5645R/5646R Instrument Design Libraries.
PXIe-5645R
PXIe-5646R
