Difference Between NI ELVISmx and NI ELVIS III Software Bundle
Updated Jul 26, 2024
  • NI ELVIS III
  • NI ELVIS II
  • NI ELVIS II+
  • NI ELVIS III Software Bundle
  • LabVIEW ELVIS III Toolkit
  • NI-ELVISmx
  • What is the difference between NI ELVISmx driver and NI ELVIS III Software Bundle?
  • Can I install both driver on the same PC?
NI-ELVISmx provides driver support for NI ELVIS II series and NI myDAQ hardware where NI ELVIS III Software Bundle includes the main software you need to build embedded applications for the NI ELVIS III, including LabVIEW, LabVIEW Real-Time Module, LabVIEW FPGA Module, LabVIEW ELVIS III Toolkit, Multisim, and others (all the software included in this bundle can be checked in the Readme and Release Notes). The last version available for this bundle is 2021 SP1 because this is the last version available for the LabVIEW ELVIS III Toolkit. However, you can use your ELVIS III without the LabVIEW ELVIS III Toolkit and with the most updated versions of LabVIEW and its modules (i.e. Real-Time Module and LabVIEW FPGA Module).
There are no issues with installing both the NI-ELVISmx driver and the NI ELVIS III Software Bundle on the same PC.
Installation of the NI ELVIS III Software Bundle is not required if you want to use the Soft Front Panels (SFPs) only.
