TDMS MinimumBufferSize Property Causes Error -2507 with Multiple References
Updated Aug 13, 2019
I have been using the MinimumBufferSize property when writing TDMS files to reduce fragmentation. When using multiple references I find the TDMS file corrupts or I receive "Error -2507: Invalid group name and/or channel name".
To use the MinimumBufferSize property you will also have to set the NI_InMemoryWriteBlockSize for each Group or Channel which the MinimumBufferSize property is set for. This is done in the same way as the MinimumBufferSize property using theĀ TDMS Set Property VI.
