Can I Use TSN in cRIO Platform?
Updated Apr 26, 2021
  • cRIO-9045
  • cRIO-9049
  • cRIO-9047
  • cRIO-9043
  • IC-3171
  • IC-3173
  • cRIO-9909
  • cRIO-9035
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
  • NI-RIO
I have a cRIO 9049, can I use TSN (Time-Sensitive Networking) in this device?
Yes, you can use TSN in your cRIO-904x, cRIO-905x, IC-317x, cRIO-9035, and cRIO-9039, but it’s important to take into account some considerations regarding the version of your software.
Please review the following Table:
TSN software
Min. Software Stack with the TSN 17.0 DriverMin. Software Stack with the TSN 17.5 DriverMin. Software Stack with the TSN 18.0 DriverMin. Software Stack with the TSN 18.1 Driver
LabVIEW 2017LabVIEW 2017 SP1LabVIEW 2018LabVIEW 2018
LabVIEW Real-Time Module 2017LabVIEW Real-Time Module 2017LabVIEW Real-Time Module 2018LabVIEW Real-Time Module 2018
LabVIEW FPGA Module 2017LabVIEW FPGA Module 2017 SP1LabVIEW FPGA Module 2018LabVIEW FPGA Module 2018
CompactRIO Device Drivers May 2017 (17.0)CompactRIO Device Drivers December 2017 (17.6)CompactRIO Device Drivers May 2018 (18.0)CompactRIO Device Drivers June 2018 (18.1)
TSN 17.0TSN 17.5TSN 18.0TSN 18.1
LabVIEW 2017 FPGA Xilinx Compilation Tool for Vivado 2015.4  (optional)LabVIEW 2017 FPGA SP1 Xilinx Compilation Tool for Vivado 2015.4 (optional)LabVIEW 2018 FPGA Xilinx Compilation Tool for Vivado 2017.2 (optional)LabVIEW 2018 FPGA Xilinx Compilation Tool for Vivado 2017.2 (optional)
DAQmx 17.1*DAQmx 17.6 is included with the CompactRIO Device Drivers 17.6 and laterDAQmx is included with the CompactRIO Device DriversDAQmx is included with the CompactRIO Device Drivers
*Only needed if you need to control a TSN cDAQ from a cRIO (sync).
For cRIO-904x series, the minimum required software is the Software stack 2018, Therefore as you are using cRIO 9049, you need to use at least LabVIEW 2018.
Find the links to download this software in the NI TSN thread: Installing Software and Hardware Setup for NI TSN Devices
National Instruments has a page dedicated to all TSN users. LABVIEW TIME SENSITIVE NETWORKING (TSN)
