Terminate Test Program From Handler/Prober Driver
Updated Aug 23, 2019
  • TestStand
  • TestStand Semiconductor Module
I'm currently using the TestStand Semiconductor Module(TSM) to develop a test program for my DUT.  I'd like to automatically terminate the test program and run ProcessCleanup if my handler or prober returns a certain error.  Is there a way to do this?
TSM allows the developer to create their own handler/prober sequence file.  For information on this, please see Creating a Handler/Prober Driver Sequence File (TSM).
The StartOfTest entry point in this sequence file controls whether or not to continue testing DUTs.  If you set the ContinueTesting parameter to false in this sequence, the test program will not execute.  All executions will terminate and ProcessCleanup will be run.
