Contactless Terminal Level 1 Type Approval
PCD Analogue Test Bench and Test Case Requirements v3.0a
- Test Case TA13x(x=1 to 9)
- Test Procedure :
STEP7) Make the EMV – TEST PICC return the response described in Table C.1 of Appendix C, Frame Trail for PCD Type A tests.
In this scenario, the FSDI expected is only 8. So RATS is only "E0 80". No others FSDI values are defined in the scenario, although FSDI can be in range 08h-0Ch.
