What OS is installed by default on USRP-2974?
Updated May 21, 2025
  • USRP-2974
  • NI-USRP
  • NI Linux Real-Time
I recently purchased USRP-2974. Unlike traditional USRPs, I heard USRP-2974 can run as an embedded system. Which OS is installed inside the USRP-2974?
By default, NI Linux RT is installed on USRP-2974. NI Linux RT is a Linux-based RTOS developed by NI over many years. This OS combines the usability of Linux and the determinism important factor for Real-Time OS.
If you are having trouble connecting the USRP-2974, or if you want to install a different OS on the USRP-2974, please see the related links below for more details.
Issues related to programming with USRP-2974 are also covered in the Related Links section below.
