Error When Creating a Read With Abort from a One Element Stream
Updated Aug 23, 2019
Programming Language
  • LabVIEW G
I am creating a One Element Stream channel wire with abort. I can create the "Write With Abort" just fine, but when I try and create the "Read With Abort" I get error -1055. How can I fix this?
This is a known issue with LabVIEW up to version 2019 and has been noted in the corrective action request (CAR) #742791. The current work around is to create a "Read" without the abort and then right click the Read function, select Replace>> Channel Endpoint>> "Read With Abort". This will then populate the "Read With Abort" and the functionality you are looking for.
