Is SQL DataPlugin Avaliable in DIAdem 2018 or Newer?
Updated Feb 20, 2023
  • DIAdem
Other
  • SQL Server database
I can connect to SQL Server database in DIAdem 2015 32-bit by adding new Data Store. However, I can't find SQL DataPlugin in DIAdem 2018.
The SQL DataPlugin is no longer available in DIAdem 64-bit. Since DIAdem 2018 and the newer versions are only available in 64-bit version, they will no longer support SQL DataPlugin. SQL Server database can't be accessed by adding new Data Store in DIAdem 2018.
If you want to connect to SQL Server and other databases, you can use ActiveX Data Objects in VBScript.
