Unable to Find the DIAdem DAC in DIAdem
Updated Aug 1, 2019
  • DIAdem DAC Bundle
  • DIAdem DAC Kit
  • DIAdem
I am using DIAdem to acquire data from NI cDAQ module. I am unable to see the DIAdem DAC in my DIAdem. The DIAdem DAC should be exist in the vertical tool bar in DIAdem as shown as the figure below:
The DIAdem DAC will not exist in DIAdem if you are activate in Student Edition.
  • To solve the problem, you can deactivate the Student Edition of DIAdem in NI License Manager. To access into the NI License Manager, you can follow the directory of National Instruments >> License Manager >> NI License Manager.
  • In the NI License Manager, direct to Local License. Look for the DIAdem that you are using and deactivate the Student Edition.
Does't not require PC reboost after you the deactivation of Student Edition. You can direct use your DIAdem for your application now.
