How to Slow Down VeriStand Model Rate
Updated Feb 23, 2023
  • VeriStand
I have several models to run at different rates in Veristand.
Can I slow down the model rates? Where I can find those set up?
Yes, You can use the Decimation control to change the model rate.
However, the model rate only can be decimated from the Primary Control Loop Rate(PCL).
The model rate is determined by Model Rate = Primary Control Loop Rate/decimation
You can configure the Decimation parameter as shown below
