Error 1003 Cannot Execute LabVIEW NXG Application
Updated Nov 18, 2019
  • LabVIEW NXG
  • LabVIEW NXG Application Builder
LabVIEW NXG application cannot be executed with error -1003. I refer the following KB, Error 1003 When Running NXG Application, but the problem remains. Is there any other solution?
If you don't solve the problem with KB above, try to solve it with the solution below.
If you have a non-English language in the file path you are saving, try to change the language to English. In this case, I recommend that even the file name should be changed to English.
This is not the solution to all problems with Error -1003. Therefore, if the KB above does not solve the problem, consider this KB as one of the trouble-shooting.
