PXIe-2524 pinout with 160-Pin DIN Cable
Updated Apr 21, 2023
  • PXIe-2524
I would like to use my PXIe-2524 with a 160-Pin DIN cable. I found the pinout in the DIN cable's documentation for the PXIe 2520, 2521, 2522, 2523 and 2510 but not for the 2524.
Is the cable compatible with my Multiplexer? If yes, how do I find what pin on the module goes where on the DIN cable?
Yes the four terminal DSUB DIN Cable (SH160DIN-4XDB50F-2A) is compatible with the PXIe-2524 Multiplexer module.
You can find the pinout of this configuration in the multiplexer's specifications. On Figure 2. Page 8 you can see an image of the high density output terminal of the module. On this picture every pin is connected to a label showing the name of the pin. Next to the line connecting the labels with the pins a letter and a number is visible. This show you the corresponding DSUB connector and the pin of that connector when using the 160 DIN connector.
